How to write Data from INI file to Ring control
Hai,
My requirement here is to update the Ring value by the data from INI file. In that RING i have items added already.In that i need to select the particular item that is mentioned in INI file. For Eg: if i have the values like 1200,2400,4800,9600,19200 in the RING and the Value read from INI is 9600, in the RING menu 9600 should be selected.
Message 11 of 15
(1,118 Views)
Now you have changed your requirement. Initially you told to write to ring as mentioned in your subject. Now you are telling something else.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 12 of 15
(1,115 Views)
Accepted by topic author Sakthimurugan_Elek
In that case read ini file and read the string. Later in the ring read row by row and compare with string.If matched then stop otherwise read next.
--Ranjeet
Message 13 of 15
(1,114 Views)
I was using a case structure to decide which value to the menu ring. If 4800 was read from ini, then 4800 constant would asigned to menu ring. Actually I used system ring instead of menu ring.
Message 14 of 15
(1,067 Views)
Looks like you do have some problem, This is solved now. Post different question along with what you want and what you have tried?
--Ranjeet
Message 15 of 15
(1,065 Views)
