How to write Data from INI file to Ring control
Hai,
I need to write the Data read from INI file to a RING control.While doing this operation using Variants i am getting error.
I will be pleased if somebody help me.I have attached the Particular INI file and the VI.
Message 1 of 15
(4,630 Views)
Tell me how to read data from ini file.Writng part I will do
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 15
(4,621 Views)
I am reading a key value inside a configuration file and i need to update that key value to a Ring control. While doing this operation,the ring control is not getting updated in a right way.For eg let us consider values like 1200,2400,4800,9600 are in a Ring control and the value i read from INI is 9600. By wiring the reference of the ring control to the generic control property node, i am updating the Ring control value. But its getting updated as <3>.
Sakthimurugan.S
Message 3 of 15
(4,619 Views)
For reading the INI data i have attached the VIs and INI file.Please consider that. It is LabVIEW-2010 version.
Sakthimurugan.S
Message 4 of 15
(4,618 Views)
Adding data to ring
--Ranjeet
Message 5 of 15
(4,610 Views)
Sir,
Please save the VI for 2010 version and upload it.
Sakthimurugan.S
Message 6 of 15
(4,606 Views)
Here in 2010
--Ranjeet
Message 7 of 15
(4,600 Views)
Dear sir,
Consider the VIs which i uploaded in my query.I need to update the controls inside a cluster by reading the data from INI file.
So, In that i used the reference of controls for finding the control type and with that reference i need to update the value.
Thanks for your kind support.
Sakthimurugan.S
Message 8 of 15
(4,587 Views)
I have not yet got the solution for my query. I expect somebody can able to help me. Consider the VIs which i uploaded in my question part.
Sakthimurugan.S
(CLAD)
Message 9 of 15
(4,547 Views)
What else you need? I showed you how to write data to ring.Now you can modify accordingly.  If you are expecting someone to write your complete VI then its difficult for me atleast.
--Ranjeet
Message 10 of 15
(4,542 Views)
