How to use "Read JPEG File VI "??
Hi!
I have a question, I´m doing this:
I am using the "Read JPEG File VI " to select a photo and then show it in a box, everything is fine here, but my doubt is when the file explorer shows up to select the photo, it shows any kind of files, I mean, if there are PDF's, .doc, .xls, mp4 files, they appear. How can I do to if I want the file explorer to show just png or jpg files?
I will attach a screenshot of my code, it just read a photo from a path, then it is shown in a picturebox and the photo is fixed to fit in.
Thank you!!!
(2,891 Views)
Accepted by topic author paco09
You can (1)  Use the File Dialog Express VI and specify a pattern label and pattern:  Enter something like 'JPEG images' for the label and '*.jpg;*.jpeg' for the pattern.  Or 'Images' and '*.png;*.jpg;*.jpeg;*.bmp'
If you need multiple filters you can try this
https://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-05-10-2010/m-p/1127402?query.id=3663527#M497...
unless you are using LV2019
https://forums.ni.com/t5/LabVIEW/Null-File-Dialog-Behavior-in-2019-amp-Forward-Compatible-Run/m-p/39...
(2) Right-click the path control and choose Browse options, specify the Label and Pattern.
(3) Set the label and pattern for the path control using property nodes
(2,863 Views)
Thank you  Darin!
(2,767 Views)
