How to use labview to control the horizonal menu of TDS420A?
Hellow!
anyone can tell me how to control the horizonal menu of TDS 420A osilloscope? currently,i use "TKTDS 420A config.Horiz.VI and TKTDS readwaveform.VI to control the horizonal menu,i would like to control the delay time to get a specific part of the whole waveform,but it doesn't work,attached is a example,anyone can tell me the reason? thanks!
(3,015 Views)
Your vi won't load on our machines without the TDS' driver. If you "Save with options" as a "Development Distribution" it should include the required sub-vi's. The be sure and "zip" the resulting .llb file to reduce its size.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,001 Views)
thanks! Attached is modified file.
(2,997 Views)
happybird,
I'm not going to be of much help since I don't have access to your instrument. Does one of the getting started examples shed any light on this? What exactly are you trying to accomplish?
Craig H.
(2,978 Views)
Here is an example of how I read data from a yokogawa dl708 scope.
(2,970 Views)
