memory couldn't be read
when I am running my program I have the following message.see attachement.
How to solve this issue?
(2,654 Views)
Investigate where you use Call Library Nodes in your app. Then carefully examine all of them to use the correct parameters and buffer sizes.
Rolf Kalbermatter
Message Edited by rolfk on 06-21-2005 08:27 AM
Rolf Kalbermatter  My Blog
(2,649 Views)
This can also be a memory leak due to unclosed references to LV objects in the code.
I got this sometimes from a sub-VI of mine which made extensive use of LV object references.
DLLs and CINs are also very likely (perhaps more likely) candidates.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,644 Views)
