On Tue, 04 Jan 2000 15:20:17 +0100, Rainer Rawer
wrote:
>IS there a simple way to interface/use an HPIB-card (HP 82350 PCI) in
>LabVIEW ?
You will have to install HP-VISA and configure it for the use with
LabVIEW by running the LabVIEW Solution Wizard/Instrument Wizard.
After this you should be able to use the LabVIEW VISA-functions to
communicate with the HP-GPIB card. Using the LabVIEW GPIB-functions
will not work.
