How to use a boolean to log time?
Hi all,
In my application, I want to use a boolean to log a time on continuous bases. When boolean gets 1, it logs system time. When boolean gets 0, it logs system time...& the cycle goes on.. We can use push button for changing boolean value...
Please guide me,,
Thank you,
Vaibhav Gandhi
B.E. Instrumentation & Control,
INDIA
(2,975 Views)
Use the event structure to implement the logic.
Trigger the event for value change property of the boolean and have a text file to write the system time. There are vi's which readily takes the system time and gives it to you.
Guru
Guru (CLA)
(2,961 Views)
Accepted by Vaibhav G
Hi vaibhav,
 I created a switch control,whenver its state is changed..that particular time is logged...Check the attachment..
Thanks and regards,
srikrishnaNF
Srikrishna
(2,960 Views)
Hi shrikrishna,
Thank you so much its really working...I want date also to log with time...I will make suitable correction...
Vaibhav Gandhi
INDIA
(2,902 Views)
