How to use VISA + USB001 instead of COM1
hello
I need to communicate programmatically to a printer that was first installed via COM1 RS232 and configured with VISA functions
(document joined, LV2012, sorry for the old bad code)
now it's not working anymore and I would like to use the USB input instead. in the printer properties, the printer is defined as USB006
When I change my VISA initialisation node from COM1 to USB006? if not is there another way?
regards
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(3,011 Views)
You could try communicating with it using USB RAW mode.  However, a lot of devices use different communication over USB than they do serial, so the chances that this will work aren't super great.
(2,978 Views)
Hi Pierre,
Why don't you replace the PC COM port by a simple USB-to-RS232 converter? They are cheap (in the order of ~10€)…
(2,962 Views)
I will try the converter and keep you informed
thanks
(2,949 Views)
