How to use C# other class
I have one C# DLL. In C# dll, I have three Classes (Class1、Class2、Class3).
I through Labview .Net function use C# DLL. But I just see Class1, I don't see Class2 and Class3. I want to use Class2 and Class3 I need to do what?
I add a new method in Class1. I want to use the new method. But through .Net function I can't see the new method, I just see the old method.
(1,725 Views)
Are you using a LabVIEW Project?
Where do you put the .NET assembly on disk?
What happens when you re-start LabVIEW and re-open the VI?
(1,677 Views)
1. Yes
2. D Slot
3. When I restart I can see a new method, but still is not see other Classes.
     If I don't want to restart and I can immediately use a new method, I need to do what?
(1,657 Views)
Are Class2 and Class3 public classes (not private or internal)?
Are they defined as non static (static classes do not have public constructors)?
Otherwise we'll take a look at your posted code.
(1,651 Views)
Accepted by JustTest
I checked your assembly, and both Class2 and Class3 are defined with no access modifiers (and are thus implicitly internal by default).
Internal classes cannot be accessed outside the assembly https://docs.microsoft.com/en-us/dotnet/csharp/programming-guide/classes-and-structs/access-modifier... regardless of the application hosting the assembly.
Change them to public, recompile, and try accessing them in LabVIEW again.
(1,644 Views)
I finally know why.
I forget to add "Public" in Class2 and Class3.
(1,638 Views)
