How to upload a file
How to upload a file onto a webpage using LabVIEW FTP server .
I want to update every minutes and export to Excel files.
Could you kindly help me to find the example regarding this matter.
Thank you for your help and your supports will be highly appreciate.
Wasin  Pensungnoen
(3,382 Views)
Accepted by gameafro
Hi Wasin,
Thanks for the post and I hope your well today.
Are you using the Internet Toolkit?
If so refer to the NI Example Finder for examples of using FTP VIs and the Internet Toolkit.
Internet Toolkit Basics
http://zone.ni.com/devzone/cda/tut/p/id/3534#toc3
Genereal Overview and guidence
How Can I Use LabVIEW to FTP Files to and from My Real-Time Target
http://digital.ni.com/public.nsf/allkb/3D985C3C08C12D0B862574BB005A7684?OpenDocument
Useful Knowledge base with others linked.
Hope this helps to get you started,
*added,
To be a little more helpful, there is an example titled FTP Generated Data.vi which generates data and allows the user to save the data to disk in binary format and then upload the file to a designated site. The VI uses the configuration found in the internet.ini file.
Just trying to help 😄
Message Edited by Hillman on 01-05-2009 11:14 AM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,367 Views)
It's very good way for me to learn from you.It's very helpfu when someone gave the idea to learn.
Thank you so much for your times and I'm appreciate from your help.
Wasin Pensungnoen
(3,330 Views)
Hi Wasin,
Thanks for the reply and kind words.
Glad I could help.
Kind Regards
James Hillman
(3,314 Views)
