How to update shared variables within a project
Hello everybody,
I want to carry data within my VIs and I'm using shared variables. Sometimes the value of the data has to be updated so the following operations are done: writing of the variable in VI#1, reading it in VI#2, writing new value it in VI#3, reading it VI#2.
My problem is that the value is not updated. I search the forum and the help but I could not find any thread addressing this issue.
Thanks in advance for your help.
Sylvain
(3,151 Views)
...sounds to me as if this could be a data flow related issue. Could you post a simple example of your code or a screenshot of what your a doing?
(3,123 Views)
Thanks for your reply.
Here is a short example.
At the beggining (VI#1), the user is asked to log in. If it is user morelsv, it is possible to activate the test mode.
Then other VIs are run and finally in VI#4, depending on whether the test mode has been activated or not, different actions will be made.
Now, my problem is:
user morelsv logs in and activate the test mode -->test mode = true
user morelsv logs off.
another user logs in so test mode changes to false (VI#1) but in VI#4, test mode still = true... no update of the shared variable is done.
I hope that helps to understand my issue.
(3,115 Views)
Hello!
I don´t know, what your LabVIEW-Skills are, so perhaps this answer is silly for you:
When the new user logs in, is the loop in V4 still running? What I see from your Screenshot (V4), the variable is read only once at the beginning of the VI. Changes to the Varaible have no effect, so it can´t work.
If that is not your Problem, is this your flow?
1. User 1 logs in, Variable is written, Pause, VI 4 starts, Variable is read, Loops starts, User 1 logs of, VI 4 stops
2. User 2 logs in, Variable is written, Pause, VI 4 starts, Variable is read --> False Value
Do you share your variables over the network? When you use only one Computer, try just for testing a global variable and see if this works. Helps finding the error: if it works with a global variable, we look further at the shared variable, if not, we should look closer to your programm.
Regards
(3,098 Views)
Hello.
My labview-skills are very poor since I never had proper training. All information is then welcome 🙂
When the new user logs in, the loop in V4 is not running anymore.
Also, I believe that my flow is correct, otherwise I would have other issues (for instance the user ID would not be correct)
I have actually no need to share these variables over the network. I have replaced the shared variable with a global variable and it works fine.
For the need of my programm, the issue has been solved.
I would be however be curious to understand why the upate of the shared variable failed.
So thank you very much for your help.
Sylvain
(3,060 Views)
