How to update numeric indicator with digital input
Hello guys,
I am attempting to write code to do the following;
The USB-6501 P0.0 connected to a switch that is held high via a resistor.
The switch is pressed and I can detect the input (my Panel LED changes color).
I need to update a numeric indicator (I think that is the correct vi I should use) everytime the switch is pressed.
Any assistant will be much appreciated.
Message 1 of 25
(4,959 Views)
What do you mean by "update a numeric indicator"?
What do you want it to show?
Message 2 of 25
(4,947 Views)
Update with what value? Do you want to count the numer of presses?
Message 3 of 25
(4,937 Views)
I would like to display the number of times the switch has been pressed. I meant numeric constant.
Message 4 of 25
(4,935 Views)
Yes, that is correct.
Message 5 of 25
(4,933 Views)
actually it is numeric indicator is correct.  you can think about the logic necessary to qualify as a change/increment, and that is what you have to program.  And actually for the hardware you are using, I believe there are built in counters that you can use to make your life easier:  http://www.ni.com/pdf/manuals/375267a.pdf
Message 6 of 25
(4,919 Views)
Yes, the output of the source is 1D Array (TRUE or FALSE) and the type of the sink (numeric indicator) is a double. I am having trouble connecting them together.
I did notice my device has the event counter as shown in the document. Perhaps I'm approching this in the wrong way since I need to have 8 switches and each has their own numeric indicator.
Message 7 of 25
(4,899 Views)
You should be able to just use a counter to read in the number of edges so you don't even have to convert from the arrray:  http://www.ni.com/f/students/12/7353/en/
But if you want to go that route, you can use a for loop to go through each index of your array.  Just make a for loop, then wire your array into it, and you will see that it automatically takes each index for each iteration of the for loop.
edit to answer your edit:
So, if you have 8 switches, it would make sense as to why you might be getting an array of 8 boolean, because it is for each of your inputs.
Message 8 of 25
(4,887 Views)
Store the number in a shift register.  Use boolean crossing Pt by Pt to determine when the switch changes.  When that is true, then add 1 to the value going into the shift register.
Message 9 of 25
(4,884 Views)
Pardon my ignorance, what is PT by PT?
Message 10 of 25
(4,875 Views)
