In article <50650000000500000044C80000-1042324653000@exchange.ni.com>,
"Chaitanya" wrote:
> Hi Mr.Adam,
> Thank you for responding to my question. As you mentioned, I have
> thought about the step by step algorithm. But,I get stuck to the same
> point. I just want to know how can we tune external component by
> programming(not by turning some control knobs in front end) such that it
> inturn changes the voltage level of another component.For example, i
> want to tune two components by programming ,in circuit. Let them be
> volume knob components so that the output of other two
> components,say,speaker controls,gets to desired level. Thanks
Sounds like you need a board with and analog to digital converters (ADCs)
and another with
digital to analog converters (DACs). Use the ADC board
to check your signal and the DAC board to set it. Depending on the signal
you're checking or setting you may need some signal conditioning so you
don't damage your UUT or DAQ boards.
If these "knobs" are potentiometers then they're probably acting as
voltage dividers. A DAC channel and signal conditioning will replace one
of these. Most of this stuff is off-the-shelf. Check out
www.measurementcomputing.com for cheapy stuff, NI to impress the chicks,
or jameco for home-grown DAQ stuff.
bon chance!
- Kevin
