How to trigger user events inside Action Engine (or FGV) between multiple VIs?
I tried to use the AE to trigger user events in two VIs, but not successful. Only one of them can trigger the other depending on which starts first. What's the best way to to make a two-way communication (trigger)?
(3,052 Views)
Hello Ishi,
Can you give some extra information about the actual application?
This would allow me to have a better insight into the issue your running into and the possible solutions.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,028 Views)
