How to trigger a user event from two different sources?
I've liked an example from my previous statement.
You can have a menu reference in your consumer loop if you want to process any data or to set up data with Menu actions from the palette.
Message 11 of 20
(1,532 Views)
@MaSta wrote:
I wonder why no one looks at the pictures I showed above. Accessing the custom menu triggers an event, the MenuItemTag is read into a multicase (not shown in the simplified VI). OK, new image:
Because I and many others are very bad in debugging pictures! Attach your code, and do a save for previous if you use one of the latest LabVIEW versions.
As has been already pointed out if you have an event case handle multiple events, LabVIEW will only let you select attribute nodes that apply to all those events. It can't invent values of attributes that an event doesn't provide and correctly disables them in the selection.
If you want to have access to that attribute you need to handle the event in its own case. And if you want to have common code execute in both cases there are a few solutions that avoids code duplication. The first and most obvious would be to place that code in a subVI and call it in both cases. If your application gets more complicated you may however anyhow want to go to a state machine design. And then you put that code in a specific state and simply send the state machine handling into that state from both event cases.
Rolf Kalbermatter  My Blog
Message 12 of 20
(1,531 Views)
Please consider working on your communications skills. Multiple people replying in confusion should give you pause and make you try to give a better explanation. Being rude will not motivate others to help you. You may note that I correctly guessed the actual problem and provided two possible solutions in my answer above. Others have now provided a worked out example.
Message 13 of 20
(1,529 Views)
I'm sorry, but I cannot alter the thread title anymore. I learned that user events and events in the event structure are not the same.
The correct thread title would have been "How to trigger an event in an event structure from two different sources?", but as I already learned that's not possible.
@t.n14: Nice idea, but it would give me an empty menu item tag in the event.
Message 14 of 20
(1,496 Views)
To access the data from multiple combined events - the data types and names must match.
If you combine a Boolean event and a String event you won't be able to see their data.
Two examples are attached. Both combine two Boolean events.
One version uses an ugly technique of two events with the same name.
The other one uses clusters to allow unique event names.
An interesting feature of dynamic events is that cluster data is unbundled in the event.
Usually this is helpful but if you want the cluster you must add another cluster level.
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 15 of 20
(1,477 Views)
The pictures ARE the code, simplified. The code inside the event doesn't matter. Even the simplified code didn't work. I now know why. All good.
Message 16 of 20
(1,475 Views)
Why is wondering about something considered as rude? I showed a picture with a structure and someone asked "what is your structure?". Can you imagine how confusing that is for me?
Your intention to help in honor, but your VIs are not a solution to my problem as the question was "two different sources" not "two identical sources". LV allows you to combine two different cases into one event, but removes important refs and data so you need to get them from elsewhere. That's the problem, the question and what's shown in the two initial images. Unfortunately, the answer came from someone and was "not possible", so I gotta find a different way.
Message 17 of 20
(1,473 Views)
how about this one.
I had that empty tag, too, tried to find the cause and fix, but then it just worked as I rebuilt it. (maybe the missing viref?)
Message 18 of 20
(1,416 Views)
Accepted by MaSta
Either make a sub-vi and use in both events, or make a user event that both events trigger.
Qestit Systems
Certified-LabVIEW-Developer
Message 19 of 20
(1,391 Views)
Rude is probably not the right word but you have shown certainly obstinance in my opinion. First you start with an image. Yes images are sometimes worth more than 1000 words but in the case of a LabVIEW diagram they are often not even half of the truth. There are many things such as in hidden structure frames, popup attributes of objects, etc. that can not be examined in a picture. Together with a less than perfect topic title it makes it almost impossible to determine what you tried to do without using some magic crystal ball or other psychic capabilities. Sometimes a problem strikes something I have come across recently and then there are no psychic capabilities needed. In this case this is a problem that I have discovered myself maybe 20 years ago at one time, investigated and found that a proper state machine architecture easily allows to solve it, and moved on. It's resident knowledge deep down in my memory, but not really something I actively work with in my daily work simply because I pretty much always start with a state machine and if I need to handle different events I ALWAYS let them have their own event case and trigger the according state transition from there. That's muscle memory and doesn't require to have the knowledge about incompatible events not having all the event data present in a case, at the top of my mind.
You need to consider the target audience. They haven't your problem that you tried to tinker with for some time. They come and read your post with a blank slate as far as your problem is concerned, and a picture and a few more or less well chosen words may not be enough to understand your problem.
And there have been explanations why things are the way they are and also several solutions that in all honesty are worthwhile to consider. Insisting that the mountain needs to come to you rather than you going to the mountain is an interesting concept but in all truthiness also one that is certain to fail.
Message 20 of 20
(1,374 Views)
