How to tell which commands will run in parallel?
Back to the original question.
The LabVIEW compiler is described here.
You are (apparently) saying that there is a significant difference between the two code alternatives. Sorry, I have no experience with .net at all, but does the upper code only have a single .net reference that you are branching? Just wondering if that would make a difference.
Message 11 of 22
(1,592 Views)
@fsTAS wrote:
On the value property nodes I have no idea what overuse would be.  If you can take a look at my real code and let me know if there is any, I would appreciate it.
All your value property nodes can be replaced by local variables, which are orders of magnitude more efficient. Value property nodes are synchronous and typically require a thread switch.
Message 12 of 22
(1,590 Views)
Both cases use one .Net reference. Ocean optics' driver, what they call the wrapper object, can only be opened once even when using multiple devices.  I have no idea how this affects the .Net call.
Message 13 of 22
(1,584 Views)
I had no idea. Thanks for the tip 🙂
Message 14 of 22
(1,583 Views)
Sorry, but why is index array resized to two outputs of you are only branching from the upper terminal?
Message 15 of 22
(1,577 Views)
Ocean Optics also has a certified LabVIEW driver which you might want to take a look at, though it provides slightly different functionality than the omnidriver.
Message 16 of 22
(1,570 Views)
The array is built from the same .net refferences.  The person who write that part did not realize they use the same reffernece and I haven't changed it yet.
Message 17 of 22
(1,563 Views)
Intersting... I'll have to ask them about that.
Message 18 of 22
(1,562 Views)
@altenbach wrote:
Can you show us the entire code of the upper picture without the truncation on the left and right
Ok Got it.  I've included the two peices of code that illustrate the issue I was having the best, along with screenshots of the oscilloscopes.  I don't have a four channel oscilloscope and had to use two two channels instead.  In these pitures I read two spectrums from both spectrometers and send ten hardware triggers to the spectrometers.  In the twoWhile set they both read at the same time.  The third feedback is due to the spectrometer reading one more spectrum because its output buffer is empty.  In the oneWhile set you can see that each read happens on different hardware triggers.  Again extra feedback pulses are seen due to the spectrometers reading an extra spectrum because their output buffers are empty
Message 20 of 22
(1,521 Views)
