Connectin' FBG Interrogator via Ethernet to Labview
Hello everyone. I have an FBG interrogator that senses the reflectivity and transmission of a pressure sensor. I would like to receive the reflectivity and transmission datas from the Interrogator via crosscable. I cant find the interrogator in NIMAX (not so sure should I use NIMAX or not). I need kind help of you. Your effort will be highly appreciated.
Add 273 on whatever Celcius said.
-Kelvin
Message 1 of 17
(4,474 Views)
NI makes the PXIe-4844, an Optical Sensor Interrogator for Fiber Bragg Gratings.  If you have this in your PC, MAX should see it.
Message 2 of 17
(4,467 Views)
Hmm.  I just noticed you said "via Ethernet", which I assume means you have another instrument that's actually interfaced to the FBG.  You'll have to read the manual for your instrument and see what they say is the right way to remotely access it via TCP/IP, then write the LabVIEW code to manage this.
BS
Message 3 of 17
(4,465 Views)
Sorry for taking your time. Could you please tell me what do you mean with PXIe-4844
-Kelvin
Message 4 of 17
(4,464 Views)
Bob was asking if this is the FBG you are using:
https://www.ni.com/en-us/support/model.pxie-4844.html
(obviously not since you don't recognize it 😃
Message 5 of 17
(4,426 Views)
Now I see. Yes, I have a different instrument (micronoptics brand) that is interfacing with the FBG. So, I need to receive datas from the corresponding interrogator and display the datas in the LabVIEW.
So what are your suggestions in this case?
-Kelvin
Message 6 of 17
(4,397 Views)
I have no experience with such instruments whatsoever, but MAX is only for configuring NI products so you wont see your product there.
You need to check to manual for your product to find out how it is communcating. Drivers, a protocol etc?
If you should require any more help from the forums, make sure to link to the manual!
Message 7 of 17
(4,380 Views)
That is the biggest problem perhult. There is no a detailed user manual given for the corresponding device. Otherwise, I would be glad to share much more detailed info with you guys.
-Kelvin
Message 8 of 17
(4,373 Views)
Go to the Support page of Micron Optics and see if they have LabVIEW examples for your instrument.
-AK2DM
Message 9 of 17
(4,365 Views)
Come on! You STILL havn't even told us what the instrument is called! How do you think anyone is supposed to be able to help you?
Of course there is documentation, if you havn't got any physical manual just contact Micron Optics and I am sure they will supply you with the documentation. There is plenty of documentation on their website anyhow.
Message 10 of 17
(4,353 Views)
