How to stop excel from opening while saving data?
I'm trying to save data into an excel file and I constantly use that same file to update the information. The problem is, everytime I update or create an excel file, it actually opens a excel window. I want it to create and save data without opening it for the user!
I hope I could made my problem clear...
Below you can take a look at some of the VIs I use to create and uptade information.
My comments are in Portuguese, so I gave you the hole VI, so you can use the help option to get what's going on.
Thanks for the attention!
Smiley Happy
(2,885 Views)
Set ActiveX Property Node ->Application -> Visible to False
(2,882 Views)
Accepted by Evps
ok, so... i got the answer for my own problem... i was working on it for about 2 days and now that i asked i figure it out.
If anyone was similar problema, here is the solution:
At the New Report VI, set "no change" at window state.
Simple as that xD
(2,881 Views)
