How to stop DAQmx VIs from loading while searching
Whenever I search "All VIs in Application Instance" for any LabVIEW object or text, the search is greatly slowed down because all my DAQmx VIs feel the need to load, which takes up tens of seconds every time I do a search.
I don't want to search through them, as I specifically have the "Ignore VIs in vi.lib" box checked.
Attached is a pic showing one of them loading.
How do I stop this behavior?
(2,383 Views)
Hi bmihura,
I hope you are doing well today! Is it possible for you to attach an isolated/simple version of your code which replicates the issue? I am assuming that you are facing this issue when you Ctrl+F on the block diagram. If that's not the case, be sure to write down the steps you take to see this issue.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,368 Views)
