I'm using NI 1427 cameralink card to acquire and save images with CCAM cmos camera.
Using ROI I can increase the camera frame rate up to hunderds frames per second (FPS).
When I use the IMAQ sequence.vi to acquire a sequence of frames, the resulted FPS is much less than expected (i.e. 230 instead of 370). I'm using a flat sequnce structure with 2 clocks to estimate the acquired FPS.
When openning the camera in MAX I checked that indeed the camera works at the high FPS.
I'm working on PC with AMD Athlon64 x2 Dual 3800+, windows xp pro, 1Gb RAM, Labview7.1.1, vision acq. software 8.2.1
Can anyone spot the problem?
thanks
Omer
