How to split the string????
I am getting data like ~^1820|-93.13|+4.57|-3.20|183.62'
that all value assigned something like height, angle etc..
I want to split this string could anyone please help me How to do that.
I want in one like.  1820
                              a= -93.13
                              b=+4.57
                              c= -3.20
                              d=183.62
Thank you very much in advance.
With greetings,
Ankit.
Message 1 of 19
(4,595 Views)
Hi
Try using "Spreadsheet String To Array"  as mentioned in below image
Murali
*Kudos welcome*
Message 2 of 19
(4,588 Views)
Accepted by AnkitRamani
Hi Ankit,
use SpreadsheetStringToArray:
Message 3 of 19
(4,585 Views)
Thank you very much for your suggestion.
Message 4 of 19
(4,573 Views)
Hi Ankit,
my example shows the single elements of the array! What else do you need?
Message 5 of 19
(4,564 Views)
Thank you very much for your suggestions.
i am not gettign the first value in that case which is suggested by GerdW.
first value is after ~^ this sign.
Greetigns,
Ankit.
Message 6 of 19
(4,557 Views)
Hi Ankit,
you should not edit message when other people have posted an answer to your (pre-edit) message…
You need to "clean up" your string by removing those two extra chars at the beginning or you may start to use RegEx functions and expressions. (I'm not an expert in RegEx, so other may chime in…)
Message 7 of 19
(4,551 Views)
Thank you very much for your reply.
But in my case it is not possible to remove that signs.
because it is by default form the instrument.
Thank you very much once agian.
Greetings,
Ankit.
Message 8 of 19
(4,543 Views)
Hi Ankit,
What exactly was your problem? 😉
Message 9 of 19
(4,538 Views)
It's less scalable (so I don't exactly recommend this), but you could also use Scan  From String.
Again, I recommend Gerd's solution of using the Spreadsheet String To Array after using the Substring to remove the first two characters.
Message 10 of 19
(4,528 Views)
