How to split a string into alfa-numerics and numerics ?
Thru I/O Assistant.vi I queried a GPIB frequency synthesizer and get a string " FRq99999.999999Hz " ( this is a micro Herz synthesizer and the query shows the correct value ).
The "9"'s are alfanumerics as well as the " FRq " and the " Hz ".
Thru a string indicator I can see this complete value on the front panel.
So far so good.
But now :
1.
How could I separate the numerics ( in string format ) out of this string and convert them into numerics in order to have them displayed in some numerics graph form ?
2.
How could I delete the " FRq " and the " Hz " out of the string, so that the " 9 " 's remain and could be converted into numerics ?
This result wil be the same as my question #1 but now ther
e will be no A/N remainder.
Thanks for any help.
(3,168 Views)
> 2.
> This result wil be the same as my question #1 but now there will be no
> A/N remainder.
Scan From String with a format string of "%.;%[^0-9]%f"
Explanation:
%.; : use point as decimal comma
%[0-9] : scan all characters not equal to 0 up to 9
%f : scan for floating point number using the decimal comma
indicated at the beginning.
Rolf Kal
bermatter
Rolf Kalbermatter  My Blog
(3,168 Views)
reteb wrote:
> 1.
You could use the function "scan from string" or (what I would prefer,
but that's just personal) the match-pattern wit a patern of [0-9\.]+
You will get the number in the "Matching Strin" output.
If the number allways starts a the same position, you could even just
use the "Fract / Exp String to number" function.
I hope, this helps a bit
Marco
(3,168 Views)
I have attached a small VI which demonstrates two options given in this discussion thread (the scan from string and the Fract/Exp String To Number.
Hope this helps.
RikP
Application Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,168 Views)
Thank you guys !
I got the point and had some succes but still one problem.
At first, in the " Fract./Exp. String To Number " I got no fractional real value 99999,999999 just the integer 99999.
After some stumbling around I found that I could add a boolean constant (T) at the top side of the icon of this vi before I got the wanted fraction behind the comma.
Is this the right way or is there a more regular way ?
In the " Scan String " I also do miss the fraction ...,999999 and see only the integer.
Should something be added to the string formatting ?
And is the wanted part of the string ( 99999,999999 ), once outputted by this vi, automatically converted into a numeric or does it remain a string ?
I need numerics for graph displays.
Thanks ag
ain for any help.
(3,168 Views)
