reteb wrote:
> Thru I/O Assistant.vi I queried a GPIB frequency synthesizer and get a
> string " FRq99999.999999Hz " ( this is a micro Herz synthesizer and
> the query shows the correct value ).
> The "9"'s are alfanumerics as well as the " FRq " and the " Hz ".
> 2.
> How could I delete the " FRq " and the " Hz " out of the string, so
> that the " 9 " 's remain and could be converted into numerics ?
> This result wil be the same as my question #1 but now there will be no
> A/N remainder.
Scan From String with a format string of "%.;%[^0-9]%f"
Explanation:
%.; : use point as decimal comma
%[0-9] : scan all characters not equal to 0 up to 9
%f : scan for floating point number using the decimal comma
indicated at the beginning.
Rolf Kal
bermatter
Rolf Kalbermatter
My Blog
