How to specify initial system state in Simulation loop?
Using the Simulation toolkit, I am trying to PID control a system parameter.
Is there any way to specify an initial parameter value (or full initial state vector)? For instance, I would initially like the system to be at 10 then step to 11 at time 1, but the system always starts at 0.
I am attaching a sample VI as well as my own PID subsystem VI (Sim 1.0 cannot code PID through a transfer function block). Please let me know, Thanks.
__________________________________
Laine
(3,121 Views)
Hi, Laine,
Could you attach your VI (or a picture of the Block Diagram) to understand better what you are trying to do?
Thanks!
GValdes
(3,095 Views)
Sorry, I thought I did this on the initial post. See the attached test system (requires Simulation toolkit). It works fine until a nonzero offset is entered, then you can see the issue.
I realize I can "code around" the problem by subtracting then adding a DC offset, but this method will get messy in the bigger picture.
Thanks.
Laine
(3,091 Views)
Anyone had a chance to look at this? All I want to do is specify the initial system state for a Simulation loop. I'm sure I'm missing something simple, but I can't see how to do this.
Laine
Laine
(3,078 Views)
