How to sort and split arrays into new cluster-array?
i have three arrays A (integer), B (timestamp) and C (double).
Now i want to convert them into a cluster array. The size of the cluster-array is the number of different values in array A (here: two different values 1 and 2)
So index 0 of the cluster array contains integer 1 and two arrays with all values of the other two arrays where the index of array A is 1.
Index 1 of the cluster array contains integer 2 and two arrays with all values of the other two arrays where the index of array A is 2.
How can this be done?
Thanks and best regards
Message 1 of 11
(4,193 Views)
Something like this?
Message 2 of 11
(4,179 Views)
edit 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 11
(4,168 Views)
No, the array-size of the output array equals the size of different numbers in array A.
In your screenshot the values of  B and C in index 2 should appear as array under index 0 as they have the same number in A.
A:
1
2
1
2
B
2009
2010
2011
2012
C
10
11
12
13
Cluster[0]
1
Timestamp[2009,2011]
Value[10,12]
Cluster[1]
2
Timestamp[2010,2012]
Value[11,13]
The values in A are not always in a order. They can be mixed like [1,2,1,2,1,1,1,1,2,2,1,2,1,2,2,2,2,1,1,1]
Message 4 of 11
(4,165 Views)
How about this one:
Regards, Jens
Kudos are welcome...
Message 5 of 11
(4,156 Views)
Accepted by topic author OnlyOne
Here's a simple solution that uses the OpenG array tools.
Jim
Message 6 of 11
(4,151 Views)
Hi jcarmody,
where did you get this library? I just downloaded my version from http://lavag.org/files/file/169-openg-array-xnodes/ but i have different in/outputs of the vis...
Thx
Message 7 of 11
(4,105 Views)
here my (not so flexible) solution using conditional indexing ...
I canceled my first try , so I thought I should provide at least another solution 😉
Henrik
LV since v3.1
Message 8 of 11
(4,102 Views)
Install the OpenG Package with the help of the VI Package Manager.
Regards, Jens
Message 9 of 11
(4,099 Views)
Jim
Message 10 of 11
(4,095 Views)
