How to solve Error -1074396080 occurred at IMAQ array to color Image
hello,
i tried with your suggestions, but still i am getting same error.
Is this the same suggestion you asked me to do which I have attached in Attachment or any thing else?
thank you very much for your time and help.
Message 11 of 22
(4,110 Views)
In the same example, interchange the Img In and Img Dst wires.
-Use grayscale for IMAQ create '2' image which should be connected to Img Dst.
uday
Message 12 of 22
(4,100 Views)
Thank you very much for your kindly help And time.
As you suggested some change for vi, that I did And its work fine means no any error I am getting.
But I am not getting continues Image, could you please explain me your second point.
And what changes I need to do in order to get continues images or video.
In attachment 1 there is screen shot of vi during operation that I am not getting video properly.
In attachment 2 there is screen shot of block diagram.vi.
In attachment 3 there is screen shot in which i made some changes in my vi in that I am obtaining output directly from the IMAQ cast image, but then i am able to get  live video but not continueous detection of object.
Thank you very much for your help.
Message 13 of 22
(4,089 Views)
Accepted by topic author AnkitRamani
What change you did? you added again acquisition which was not there in your earlier post??
Can you upload your code also!!
-What you did not understand in my previous comment?
I asked you to create extra imaq buffer of grayscale type and connect that to Img Dst. and connect your image output coming from kinnect connect it to Img in input of vision assistant.
uday
Message 14 of 22
(4,084 Views)
Thank you very much.
I got your point, I will reply you after doing changes according to your suggestion and let you know.
Thank you very much once again.
Message 15 of 22
(4,082 Views)
now its working fine and detecting color also.
is there any way to detect perticulat object to kinect.
please give me any suggestion.
thank you very much once again for your help.
Message 16 of 22
(4,074 Views)
Good to know that it worked!!
-i did not understand your statement "is there any way to detect perticulat object to kinect." ??
-Do you mean detecting object? From pattern match you can detect objects.Is that same what you are talking about?
uday
Message 17 of 22
(4,070 Views)
Thank you very much for reply.
Yah the same thing, like pattern matching.
In my case I want to detect some particular pattern, its detect the pattern but the thing is when light intensity is changed then its not working properly.
Means there is no accuracy, how should I solve this problem.
Thank you very much once again for your help and time.
Message 18 of 22
(4,066 Views)
-Which method of pattern matching technique you are using?
-Gradient method is more resistant to lighting variations as NI claims.
Ref-
http://zone.ni.com/reference/en-XX/help/372916P-01/nivisionconcepts/pattern_matching_techniques/
uday
Message 19 of 22
(4,064 Views)
I am following the Target  tracking.vi form the example of labview and I did change according to that.
file:///C:/Program%20Files/National%20Instruments/LabVIEW%202012/examples/robotics/Vision/Target%20T...
thank you very much once again.
Message 20 of 22
(4,057 Views)
