Salutations,
Well, you can always build your own model by solving the equation for the system. Then using formulae nodes to apply the information to the constants that you have, ie, mass, spring constant, damping constant, if there's friction etc... You'll be able to generate a solution. I've done this process before in a system dynamics class, so I know it's possible and normally not really painful. Depends on how many ideal assumptions you want to make etc... I'm not sure what assumptions simulink makes, that'd be something to investigate prior to using it.
I found:
http://www.music.mcgill.ca/~gary/614/week5/lumped.html
Has a rather indepth approach at how to solve such systems. Just as most places do, they assume a linear spring, and i believe a lot of ideal situations. So, this might require you to do some tweaking, but it'll provide a starting ground.
Now, is there an easy way that doesn't involve you using some system analysis? Buy the tool kit; maybe it'll offer the desired information, I really don't know.
Sincerely,
ElSmitho
