How to show 1_D array from output of scriptnode to a chart
Shouldn't I just put the array name as the output, and then connect it directly to chart? It shows nothing in that way
(2,688 Views)
It is strange that the output array from the script can even be wired to an text indicator?
(2,673 Views)
Oh , I made a mistake, I didn't assign the type of the output. When I changed it to 1-D array ,and it can only connected to chart now.
But after it runs, still nothing shows?
(2,670 Views)
Pleas post your code, as it will be easier to understand what it is that you're doing and what might be wrong.
(2,657 Views)
