How to add variables as strings in an image .JPG, I should do this before creating the file or after?
Hello everyone,
I have a VI that makes the acquisition of ultrasound images and save frames using "Write to JPEG FILE.vi". The problem is I need to add information (variables such as string and numeric) in these frames.
Here is my VI, it uses a DLL to process the image, output_bilinear is an array that is linearized through another dll (smallest) to enter (output_bilinear_vector 2) the "Write to JPEG FILE.vi"
What should I do, enter this information before saving the JPEG file (by some how editing the matrix) or should I edit the JPEG after create(using some image editor)?
Please help.
(3,764 Views)
Unfortunately you can't do this so easy...
What you can do is following:
- if you using Vision Toolkit, save data to PNG. There are some functions available for writing your custom data to PNG.
- learn how to store user data in jpeg. For example, EXIF data stored in jped as custom data. Search in internet how it organized.
- simply add your data directly at the end of JPEG file. As far, as I know, JPEG file have postfix, so, may be your info will be just ignored by common programs, but you will be read this info back (not checked how it works - just try it).
Andrey.
(3,757 Views)
unfortunately I do not have the vision toolkit, but with it, as would be done?
the other two options, the information would not be visible in the image?
I need this information to be recorded and visible in the images, like a date and hour at a photo.
thank-you
(3,750 Views)
Yes, but not with JPEG. In PNG format - yes.
The information will be invisible.
In case if information should be visible, then you should add this info as overlay. Also I will not recommend to use JPEG format in this case, because you will get poor quality of such overlay due to loss compression.
Andrey.
(3,734 Views)
Ok, has no problem using PNG instead of JPEG.
But how do I  add this info as overlay? I need the vision toolkit for that?
thanks
(3,728 Views)
With Vision Toolkit you will be able to create and store non-destructive overlay and custom data in single PNG file. Search forum for "IMAQ Overlay" - you will found some links. Also Vision toolkit delivered with good examples. But it will be pretty expencive solution.
Probably something linke this will meet your requirements:
Andrey.
(3,721 Views)
