How to set up directory path and open files in a software built in Labview?
I could not get this check boxes to work. If your open to a workaround without the checkboxes, then take a look at the project attached
Message 11 of 15
(1,798 Views)
Accepted by Huqs
Hello again. Find the final solution using checkboxes attached.
Message 12 of 15
(1,791 Views)
Mr. Smith, This is Absolutely fantastic!! I had another file for checkboxes with similar strategies but yours is much more enhanced. I really like the latest file you sent me. I was running it and I saw that once it loads all the files in the list box, I can click it to check on and click again to take off that check mark. But I found out, for example, let's say I put the check mark in box then go to another box to put check mark, I can check but the previous check mark will be gone. I have attached a video snippet link of what I was doing. It will make more sense what I'm talking about once you see the video.
For now, I am tinkering with your code to fix this problem. If you have any suggestions please let me know. I thank you again for your help.
https://drive.google.com/file/d/0BxB8Q3FC3r9WQ1dWQ3gzdUVlQzQ/view?usp=sharing
Message 13 of 15
(1,783 Views)
That´s odd. On my PC that code works perfectly. I also downloaded the last version I sent you and tried that one out - works properly, too.
Did you change any of the code?
Message 14 of 15
(1,769 Views)
I did not change any part of the code. I am just running it in my 2015 version. I will download again and see if the problem is still there. If the problem is still there, I will tinker and try to resolve it. Otherwise, this is the file what I was essentially looking for. This is actually a segment of an application that I am working on. I may seek your help for other segments.
Message 15 of 15
(1,767 Views)
