How to set the offset for multiple Xscale?
Hello all,
I tried to set 3 XScales for the 3 waveform in one graph as attached picture.
I have the data of xscale.maximum, xscale.minimun for each waveform.
How can I make them display as attached picture? that means do not alway start plotting at the left side.
Channel Length Minimum Maximum Description wf_increment wf_samples wf_start_offset wf_start_time Start Index
CH1(Hz) 2566       10.52779553 2566 0 1904/01/01 00:00:00.000 AM
CH2(Hz) 2851       10.52779553 2851 0 1904/01/01 00:00:00.000 PM
CH3(Hz) 2376       10.52779553 2376 0 1904/01/01 00:00:00.000 AM
(1,494 Views)
It is easy to be achieved by XY Graph..
(1,459 Views)
Accepted by topic author yeah
After setting "Active Scale" all scale properties are applied to that scale.
OT, If you get the scale reference, it will return the specific scale's reference. That allows you to make scale VIs that work for X and Y scales.
(1,436 Views)
