How to set the Y index value as integer for XY graph
How to set the Y index value as integer for XY graph, such as 2,4, ..., 20
The max value is not fixed, it will follow the data change.
(3,761 Views)
Could you explain with a few more sentences what you mean? Are you talking about the y scale?
Maybe add a drawing or example VI.
(3,752 Views)
Originally it is
2, 4,  ...     20.1954
Now I want
2, 4,  ...     20 for the y axis index value for XY graph.
(3,743 Views)
Hi turbot,
there's a property Yscale.range to set min&max. So you can make your own scaling routine...
Or switch on "loose fit" for the y-scale.
(3,739 Views)
Hi Gerd!
You are an answer machine! Smiley Wink
Go Gerd Go!
Ben
(3,728 Views)
Hi Ben,
atleast it seems there's a ~6h difference between our time zones Smiley Wink
(3,726 Views)
How to rate a good answer 🙂
(3,701 Views)
