How to set the Decoration control item transparency
Hi
There is one question about how th set the Decoration control item transparency like the attached pic.When this Decoration control item place somewhere but there was  some other control item there,when it covered that place we still can see the original control.
How to do this?
(3,465 Views)
Accepted by topic author 314159ym
you need layers control
(3,440 Views)
Shift+Right click (the decoration), select the color tool at the bottom. Click the decoration, and select the top right "T" as color. Optionally, click tab to switch between the border color and the surface color of the decoration.
This will make the decoration transparent. If you want it on top of things, you need to send to front. If you want it behind everything, send it to the back.
(3,431 Views)
Thanks,it works now like that
(3,413 Views)
