How to set "stop if true" to be the default on a while loop
Anyone know of a way (ini file setting) to set the default of a while loop to "stop if true"?
(3,076 Views)
There is no setting that I am aware of. You may want to look on the following site for a listing of ini settings.
http://labview.brianrenken.com/INI/
(3,076 Views)
Hi Shan,
I concur with Jeremy re:no ini setting to do this.
But,
If I read your question as
"Is there a way to drop a while loop and have it show up configured to 'Stop if true'?"
I can now suggest another approach. (bear with me here).
I remember reading an article in LTR that explained how to create a template type of VI that you can put on your CONTROL pallette. When you click on it, the entire contents of the said VI is copied into your VI.
So,
If you can figure out what it was that I read,
and
create a VI with nothing other a configured while loop.
you are in business.
That's all I can do without breaking out the old LTR's and chasing this down.
Maybe someone with a better memory will fill fill in the blanks I have left.
Ben
(3,076 Views)
It's not worth a lot of investigation - just a convienience thing. I find that I'm changing the stop operation of a while loop to "stop if true" almost all the time. Do you know how long ago that tip might have appeared in LTR? I've got the last year's worth.
Tim
(3,076 Views)
I am guessing that ws 2-3 years ago.
Check out this link. It sounds like what I had in mind.
http://digital.ni.com/public.nsf/websearch/61A6A949B060A20186256AD900793E52?OpenDocument
Ben
(3,076 Views)
Re: above.
See step #11 for what I was talking about.
Ben
(3,076 Views)
