How to set number of plots programmically for 3D Surface control
I heve tried with 3DPlot Count property node but I get an error that  says  it is read-only property.
My plots vary between 10 and 100 and I' not in a move to set all 100 plots manually.
andrej
(3,036 Views)
You can use the Add, Remove and Remover All methods of the Plots property to add or remove plots.  Doing it in a loop should make it easy enough.
(3,034 Views)
Thank you for your help!
But I can't find this propertys, could you tell where to look for?
I enclose screnshot of Plot property node, where are all properties that I see.
andrej
(3,029 Views)
Instead of right-click -> "Create-> Property for..." you choose "Method for ..." as shown in the attached image.
(3,024 Views)
Uh, that's tricky one.
Thank you for your help, you saved me a lot of time!
andrej
(3,021 Views)
