How to set default values for inputs?
I have several inputs which are always initialized with 0 when I start the VI. I'd like save own default values for them. I've already tried just setting the numbers and saving the VI but it did not work.
(3,390 Views)
        If you want to make any data in any controls, Arrays you can right click on it select >Data operations>Make current values default or you can select EDIT in tool bar,
click on Make current values Default.Hope this helps you.
(3,388 Views)
        If you want to make any data in any controls, Arrays you can right click on it select >Data operations>Make current values default or you can select EDIT in tool bar, click on Make current values Default.
First, enter the data you want in the control or array and then follow the things Geeta said.
Post if any other help required.
Message Edited by mathan on 12-05-2008 12:07 AM
(3,355 Views)
