How to send chr$(195) in Labview (MAX)
I have an elderly Philips DMM that needs re-calibrating, using the GPIB commands.  I need to send it a character string starting with CHR$(195).  I have a GPIB-USB-HS interface and run Labview 9.  To get me going I have been using the Measurement and Automation Tool.  Sorry this is a newbie question but I can't find the answer.  Thanks
Jeremy
(3,314 Views)
Converting a numeric (U8) has actually been discussed a great number of times. Shown below are some of your options with the numeric being displayed in hex. The string constant is also set for hex display.
(3,308 Views)
So there is no simple way to do this in Measurement & Automation Explorer?  I assume I need to run the full Labview?
I wanted to check basic communication before I write any scripts, as I am a novice here.
tnx
Jeremy
(3,297 Views)
Accepted by Jeremy Owen
It's pretty simple to do in LabVIEW as seen by the examples given.
But in MAX, you can go to the VISA test panel, VI Write Screen.  Hold down the Alt key while you type 0195 on your numeric keypad.
(3,290 Views)
