How to send bytes in LabVIEW
I got a new relay.  I was able to communicate with it in C#.  (See below)
"RelaySentString = "55 56 00 00 00 04 02 B1"
byte[] bytes = RelaySentString.Split(' ').Select(s => Convert.ToByte(s, 16)).ToArray();
LocalComPort.Write(bytes, 0, bytes.Length);
I don't know how to send the command "55 56 00 00 00 04 02 B1" in LabVIEW.  May someone help me please?
Thank you.
(1,107 Views)
Accepted by topic author SonVo
Use VISA to do the communications. It just takes a string as an array of bytes. Change your control/constant to "Hex Display" and you can just type your byte values directly.
(1,088 Views)
It worked great.
(882 Views)
