How to select some index of a 2-D array into two arrays?
I have a 2-D array with the value of 1 or 0. I'd like to find those elements with value of 1 and store their index of x-y into two 1-D array (or a 2-D array) respectively. I try to use 2 loops, compare each element with 1 and use the build array function, but it just doesn't work the way I want. Does anyone know a simple and fast way to do that?
(2,947 Views)
Here's how I would do it:
Just use the iteration of the outer and inner loops to determine the current index in the 2D array and thus, which row and column you're at.
Hope this helps,
-D
Message Edited by Darren on 04-05-2006 05:39 PM
(2,940 Views)
This vi should do it.
Well Darren beat me to it....
Message Edited by tbob on 04-05-2006 04:42 PM
- tbob
Inventor of the WORM Global
(2,938 Views)
Thank you! That's what I want!
(2,926 Views)
