How to select first element of an array from a FOR loop
Hi.
I use Labview 8.5
In my application I have a "for" loop where I read some values from a device. (strings and numeric)
As you know Labview "stores" the values until the "for" loop is terminated, and then they get out into an array.
OK.
I want to use just the first element for strings and numeric, and after that to do something with him, like compare (for numeric)
For strings I used with succes "Split 1D Array" and choose "first subarray". Good.
Now, for numeric works that too, but the result is one element, array type too. I need it to be numeric (decimal) not array type, because I need to compare him (greater than 0). Then use a Case......
So, One element array in one numeric decimal ? Or array to first decimal element. How to ?
I tried with Array subset too. Same think.Smiley Sad Labview don't let me compare a 1D array with 0. It's logical, but how to convert, to have just first decimal element ?
(9,699 Views)
Accepted by topic author dsasorin
Try using the "Index Array" function. If you do not wire a value to the index terminal it will return the first elelemnt in the array. If you wire an index it will return the value specified.
Ben
(9,697 Views)
Thank you. It works now.
(9,668 Views)
