How to search for a number located anywhere in string
I am trying to search a string for a number (integer or float) without knowing its index in the string and to extract it - whether in numeric or string format.  e.g. "the number 52.63 appears in this string"; I want to extract/identify "52.63"
The functions I come across seem to expect the index to be known or the number to be at index 0.  How can I achieve this?
Best regards.
Kenoss
Message 1 of 11
(8,698 Views)
Use the Search/Split Screen primitive. I'm sure there are plenty of examples in the Find and Example screen.
PaulG.
Retired
Message 2 of 11
(8,692 Views)
Are there other numbers expected in the string? If not you can parse the string based on using the space between words as a delimiter, checking each "word" to see if it is a number.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 11
(8,681 Views)
LabVIEW does not seem to have a function to pull any number from a string. We have an example of a way this can be done LV 8.6.1
Hope this helps
Message 4 of 11
(8,676 Views)
I forgot the warning for my the previous example. If the string contains multiple numbers in various locations in the string, all numbers will get concatenated into one output number.
IE: a string like- "Yes 12 months and 5 days is acceptable"- would have an output of 125
Message 5 of 11
(8,668 Views)
Thanks all for your variety of ideas which are very helpful!!  I found using "[-]?[.]?[0-9]+[.]?[0-9]*" in regular expression input of Match Pattern function does the trick.  Am investigating the individual meanings of this regular expression.
Many thanks.
Message 6 of 11
(8,665 Views)
Many thanks.
I was about to explain, but I figured it would be quicker to just post the 'LabVIEW Help' details.
Cory K
Message 7 of 11
(8,619 Views)
If you are about to dive into the 'wonderfull world of Regular Expression' don't miss this (regular-expressions.info) site.
Ton
My LabVIEW Ideas
Message 8 of 11
(8,616 Views)
Check out [LabVIEW]\examples\general\strings.llb\Extract Numbers.vi.  Seems to work well on the example string you give in your initial post.  Is this what you were looking for?
Message 9 of 11
(8,609 Views)
Thats where I got the idea Darren, there are alot of interesting add-ons out there!...
Message 10 of 11
(8,587 Views)
