09-18-2009 03:30 AM
09-18-2009 05:46 AM
SEA cRIO GXXX combo modules come with documentation. There will be clear procedure for including your own bitfile. follow it strictly to introduce your bit file into the main vi they give. if you dont then you will get errors.
Just see if you have followed the procedure correctly.
Note: The salutation to the forum can be just Hi
no need of sir or madam...all are pals
09-21-2009 02:25 AM
The "Dear Sir or madam" was an error in the "copy/paste procedure" from the email I sent to SEA.
I followed the steps to include my own code into the Main vi that SEA gives to program the FPGA. My question to National Instruments is related with the error. I'm new in FPGA programming and I'd like to know how to debug these kind of errors.
Thank you very much
09-22-2009 03:01 AM
It seems like LabVIEW is trying to open a block diagram of a vi which is password protected. This situation happens when LabVIEW tries to compile a VI from one version to another. If the drivers are of old version and you try to call in a new version LabVIEW re-compiles the vi.
Try getting the drivers for latest version.
If you have found a work around kindly post it. Forum can know it.
