How to save to file the current temperature data obtained from Temperature controller in labview
Hi everyone,
Hoping someone can help with this since I am very new to labview:
I am using a Vi for controlling temperature using "TEMPTRONIC" instrument. This Vi was created by a former research-mate. However, right now I need to be able to save the current temperature readings to a file (.txt, etc).
I have attached the Vi for reference. The program works perfectly for ramping up the temperature on the device, but i see that there is "current temp" indicator , but it's not recording or showing any values.
Thanks in advance for your help!
(2,106 Views)
What controller are you using?  Generally, a "Set" command will not initiate a response from an instrument.  You would have to request the read value.  We need more information (ie the instrument you are communicating with) before we can help any more.
(2,014 Views)
Hello, thanks for your response. the controller is Temptronic
(2,002 Views)
Hi mavs,
So you read its manual to learn about the commands and responses of that device?
Then you need to implement some file handling in this VI to save your data to a file!
What have you tried? Where are you stuck?
You should improve this VI!
- Use a FOR loop instead of a WHILE loop when you know the number of steps/iterations before entering the loop.
- I recommend to use FormatIntoString instead of FloatToString combined with several string constants and ConcatString.
- No need to wire default values to SerialPortInit.
- Don't use BytesAtPort, it's wrong most of the times!
- You should use VISAClose after the loop…
(1,994 Views)
That's just the name of the company.  What is the model of the controller you are using?
(1,983 Views)
The model is a CMI-X Series Controller ThermoChuck Systems.
(1,965 Views)
Crossrulz, if i understand correctly then what this VI is doing is writing a temperature setpoint and reading a temperature value from controller. The "setp" command has nothing to do with reading.
Regarding data logging, it doesn't seem like you've actually tried anything, but the simplest way is probably Open/create/replace file function (from File I/O tab) at the start of your VI, with Write Text file inside the loop and Close file at the end, outside the loop.
(1,953 Views)
