How to save cluster
Hello everybody,
I was helped to write this vi, now I would save the result in a txt or excel but if I can't connect directly the cluster with the Writespreedsheet.vi.
Can you help me?
Message 1 of 8
(3,482 Views)
Accepted by franbecks
You need to iterate through your array of clusters in a for loop, unbundle them elements, and turn them into an array of strings.  Auto-Indexing on the For Loop will let you put out a 2-D array of strings you can wire to the Write to File subVI.
Message 2 of 8
(3,444 Views)
Hi fran,
convert your 1D array of clusters into a 2D array of strings:
Message 3 of 8
(3,442 Views)
@GerdW: curious if there is a way to get the cluster name and convert its value (regardless to type) to string, concatenate them and write to file.
if possible type also, for use of saving for future configuration loads.
CY (expired CLAD)
Message 4 of 8
(3,432 Views)
Yes. Look into the Programming - File I/O - Configuration File VIs. That is one of many ways.
Message 5 of 8
(3,425 Views)
I mean without knowing the cluster beforehand
CY (expired CLAD)
Message 6 of 8
(3,422 Views)
ok, figured it out
CY (expired CLAD)
Message 7 of 8
(3,381 Views)
Thanks to GerdW and
Message 8 of 8
(3,354 Views)
