How to run 3 measurement test independently
hello,
I need to perform 3 measurement tests. User is going to select which test he wants to perform ,if not selected then I need to perform all 3 tests by default. I am currently thinking about enum with case structure but not sure how to run all cases by default. Any suggestion will be appreciated.
Thank you.
(1,910 Views)
Hello Radhika
Can you be specific on what kind of measurement, how do you get user confirmation and whether these there measurements should happen in-parallel?
(1,879 Views)
Accepted by topic author Radhika_Nimbalkar
Hi Radhika,
Your enum should have (atleast) 4 items: one for each single test, one for "combined test". When the user selects the "combined test" you just call all 3 test subVIs at once…
(1,876 Views)
Can you please tell me more details about how to do "combine test" for all cases in case structure..? That will be great help.
Thanks and regards.
(1,851 Views)
Hi Radhika,
I guess your "tests" are available as separate subVIs: just have a case where you call all of those subVIs…
(1,829 Views)
I have been trying to combine test and finding any another option,but unable to do so. In my LabVIEW drop down menu doesn't show combine option.Is is my mistake or LabVIEW?
Please find the attached image.
(1,731 Views)
