How to return control to agilent 4980 after making a labview measurement?
I have been using the driver given by national instruments for the read measurement on the agilent 4980. The measurements are made fine but after the measurement is done, I can no longer control the physical LCR meter. What changes might I make to the program to return control to the physical LCR meter?
(4,246 Views)
I know on some instruments there is a local/remote button that needs to be pushed to get back to local control.
(4,233 Views)
Is there some way to do this from labview?
(4,229 Views)
Accepted by topic author hmar14
I don't have any agilent instruments, so I have no idea.  You would need to find and go through the communication manual for the 4980 and see if there is a command.  You should be able to get it from the manufacturers site if you are lucky.
Worst case there may be a reset command and then you would have to stop communicating with it, otherwise it would probably just go back into a remote status.
(4,227 Views)
Found the button. Thanks!
(4,167 Views)
If you want to do it progamatically as you asked, you just have to use the VISA GPIB Control REN function. You can use it to issue a GTL command.
(4,128 Views)
