How to restrict the string indicator
hi... In my program i want to lock the string indicator, i.e when the button is OFF(condition is false) then we can not able to change the string value means i want to lock the current value. If i use property node with text.lock, getting an error... Please tell me the solution
        Thank You
(2,978 Views)
Use property Disabled. Value 0 is enabled, 1 is disabled and 2 is disabled and grayed out.
André (CLA, CLED)
(2,977 Views)
THANK YOU FOR QUICK AND EASY REPLY
(2,975 Views)
