How to resize decorations programmatically?
I tried to use Property Nodes, but found out that the bounds property can only be read....
Is there any way that i can adjust the width and height of a front panel decoration programmatically?
(5,294 Views)
Accepted by 45fgtfj;
there is a size property that you can use on decorations. The following example shows how you could make a decoration twice as big.
David
www.controlsoftwaresolutions.com
(5,279 Views)
The Decoration class has size properties which you can use to resize it (they should be found at the bottom of the list of properties). If you're not seeing them, this probably means that the reference you have is not of the Decoration class and you need to cast it to the Decoration class using To More Specific Class.
___________________
Try to take over the world!
(5,278 Views)
Oops, never saw the "size" property.......
Thanks, guys!!
(5,264 Views)
