How to reset to default value every time I click abort execution?
Dear friends.
Question:
I do know how to reset to default by using invoke nodes, but I want to make this happen everything I abort the program (click the red dot bottom). Thank you.
sorry about multiple posts here, there was an error. but i dont know how to delete it.
Message 1 of 14
(6,702 Views)
Dear friends.
Question:
Message 2 of 14
(6,669 Views)
Accepted by sunson29
You cannot do anything programatically when you abort the VI. It just stops in its tracks.
(If you would do a proper state machine, add a state to reset all to defaults and keep running, e.g. back to the idle state waiting for new user inputs)
Message 3 of 14
(6,694 Views)
To add: Abort Execution is not a feature intended to be used to normally stop your program; you should use a Stop Control and add logic to stop gracefully, which could also include calling those invoke nodes.
Message 4 of 14
(6,676 Views)
Not to be confused with the Stop node stop.png which is exactly like pressing the abort button.
Bill
CLD
(Mid-Level minion.)
Message 5 of 14
(6,654 Views)
Yeah, I know that.
I guess I cannot make it back to default every time if I abort the simulation.  What I have now is that reset will happen only after the simulation is over.
But sometimes, I really don't want to the simulation to run completely. That's why I just keep abort it. Thanks though.
Message 6 of 14
(6,652 Views)
If you are only worried about the indicators containing stale values on the second run (until they are updated after the second simulation has completed), you can configure the VI to clear them with every new run (VI properties...execution...clear indicators when called).
Often, the controls are best left at the last used settings anyway.
Message 7 of 14
(6,649 Views)
Drop this XControl on your front panel. Every time the VI stops, the current values will be made default.
Message 8 of 14
(6,599 Views)
lol. thanks. What do you mean by VI stops? I abort the VI or the vi finished all process? Thank you.
Message 9 of 14
(6,597 Views)
Hi Paul,
I tried your VI, thank your for that.  I think it reset after the program finished all process, right?   Btw, it was not working, I do put it one front panel. But it seems that vi will keep loading something if I abort the execution.  so that I have to wait for 3- 5 sec to run it again.
Message 10 of 14
(6,595 Views)
