How to reset LED after pushing stop button?
I`m using green LED vi for indicating whether the data were properly loaded. However, if I run the same labview program more times in row, then the green LED is still on because the "value that data were loaded properly" hangs there from previous session. Is it possible to reset all LED VIs after pushing STOP button (stopping labview program).
Thank you for answers.
Message 1 of 21
(10,016 Views)
Could you attach a picture of the relevant code surrounding your boolean indicator please.
Never say "Oops." Always say "Ah, interesting!"
Message 2 of 21
(10,010 Views)
Yes, you can have a shutdown routine after the stop button is pressed that updates the values of front panel controls/indicators. If I have not understood the question correctly, post back and be sure to attach example code.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 3 of 21
(10,009 Views)
Accepted by xombox@seznam.cz
Hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 4 of 21
(9,995 Views)
Thanks Harold,
that is what I was asking for.
Martin
Message 5 of 21
(9,969 Views)
Hi Martin,
maybe you should think about re-designing your vi! Usually you initialize values (controls,indicators) at startup of the program, not at stopping it...
Message 6 of 21
(9,950 Views)
no problem happy to help
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 21
(9,949 Views)
Harold Timmis wrote:
Hope this helps:
You should really try using local variables instead of value property nodes. Sometimes none of those are needed, see attached.
I agree with Gerd that it would make much more sense to reset at program start. In the above example the LED don't reset if the VI is aborted, for example.
Message 8 of 21
(9,935 Views)
you could in the front panel initialze the LED to a false as default
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 21
(9,935 Views)
OK,
based on your suggestions I set the default value by using property node. Don`t know how else I could this accomplish. Is that OK?
Message 10 of 21
(9,896 Views)
